Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Whats the best fitting and looking dash kit? My scosche doesnt fit worth a damn. I had to shim it to fill the gap between the dash bezel. On top of not fitting, I dont like how I cut out the center bar.
Correction. I did not have a scosche. I had a metra multikit. I ditchd that for the metra 95-2009. It fits better but still had to do a little drilling to get it even on both sides. It is nicer to because you dont have to cut the center bar out. However the opening is slightly larger so you can sorta see between the trim plate and deck. I still dont have it perfectly centered in the dash bezel hole. I ve taken the bezel off so many times, im surprise the clips still hold.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
