Bad Vibrations
danfoley
Park City, UT
I have a 2000 Tahoe with a vibration through car that appears between 65-70mph. The vibration is not isolated at steering wheel. I had a Tire Center check the tires for balance. They said the front suspension was tight but that it was bad U-joints on rear drive shaft. I check for myself and found them in good shape, but replaced both of them because they were inexpensive for the most part. I rotated the tires before testing. Found that the vibration seemed different (in my mind?), it was still there. All fluids are up to levels. I am at a loss for what else it could be. Any suggestions? Thank you
BlacktopBandit76
