Auxiliary not working
E
Ed Alexander
I am going back in trying to search how to repair this. Has anyone encountered this issue?
when was it used last and did it work the last time?
if it was working recently, then check the cable tip that was last used on it and make sure all of it is still there, if the tip of the cable broke off it could be stuck inside.
if that is not the case then you could try a inserting a toothpick and wiggle it around and/or get a can of compressed air and blow some air in the port if a piece of lint or dirt got in there then that can cause a problem with the cable tip making contact inside.
Sorry the Audio Aux input is not working.
Start here^^^
Drewphil
