Auto Start and Horn
sharonvrla
Homer, Alaska
After having my 2000 Tahoe for a few months, I started messing around a bit to figure out why my horn doesn't work. I discovered the relay and fuse were removed. I replaced them. Upon starting my truck afterwards, the horn went off. Wouldn't stop until I pulled the relay. I still have no horn. I consider that a safety issue. Any thoughts on getting my horn to work properly?
Bkihum
Champion Ohio
Change the relay
PPV_2018
Molon Labe
U.S.A.
have you confirmed that it is the correct amperage rating on the new fuse and relay that you put in?
Hopefully not a clockspring issue. Does the horn pad on the steering wheel push in when you press on it?
sharonvrla
sharonvrla
Homer, Alaska
Hi, yes the rating is correct on both and the steering wheel does push in when I press on it.
Moderator
People's Republic of Colorado
Two door or four door?
Here's a link to the wiring diagram; be sure to check the links at the very top to make sure it's the correct one for your SUV.
According to the diagram (and if it's the correct one for yours), the horn switch grounds the circuit to pin 86 of the relay. This is a very common way to activate the horn circuit. Check that relay pin socket to see if it's grounded full time (it should not be) and trace back if it is. The intended grounding point ("horn switch") is underneath the airbag in the steering wheel.
I would just pull the airbag off and inspect the horn contacts, verify the contacts are working as designed and go from there.
Moderator
^^^ THIS. Pull the airbag off and disable the horn switch where it grounds. Replace the horn relay to see if it's still passing current. If it is, you'll know that it's not the horn switch, but in the wiring between the steering wheel and the horn relay control.
Does this have an aftermarket security or auto start system? If so, that's could be the cause.
sharonvrla
sharonvrla
Homer, Alaska
Could...but I know the horn works fine. The press test is fine as well. Its just that when the relay and fuse are in place is when all the demon pigs fly.
Moderator
But if the horn connection is working incorrectly (being "always grounded") the horn's relay will be energized. Don't think that just because the "press test" lets you push it and it returns fool you into thinking that all is well there. It might be, but you won't know until it's properly diagnosed.
Test the relay contact for #86 to see if it's grounded -- my money is on that fault, whatever it's caused by. If it is grounded, then the horn circuit is being grounded when it shouldn't; could be the horn switch or a short to ground in the control circuit for the relay. Not much else can cause that.
Press test doesn't mean anything other than the 4 springs are good, I just had my airbag off the other day and the stupid horn would go off pretty much anytime I touched anything, had to pull the fuse until I was finished working on my steering wheel. There are multiple points of contact inside to trigger the horn.thats why a horn will work no matter where you press it. You asked for help, that's where you need to start.
NELLY1947
Normally one or other after the relay. IMO Steering wheel pad. Or horn it's self. Remove the connector from the horns and insert a test lamp. Look to see if it goes on and stays on. Or If it acts as it should. then the horns can be bad. They can rust out inside
sharonvrla
sharonvrla
Homer, Alaska
That makes sense....the only thing is that the horn definitely works, just not when it should. If I put the relay in place and use my key fob to unlock the doors, the horn goes off....if I then take the relay out and start the truck and then put the relay back in, the horn doesn't work when I press it.
justinakay79
