auto ride delete rear only
the blur
Cyber Space
Is there a plug and play rear resistor for autoride in the rear only?
Some of these kits you need to hack up your harness.
T
the blur
Cyber Space
The years are screwy on amazon. They list our trucks till 2012. Mine is a 2013.
T
the blur
Cyber Space
Apparently, the rear shock connector changed in 2013, and is not consistent. 2013 can be 2 or 3 pin, and no one makes a plug and play device. Hack off the connector only.
mikez71
De-pin the terminal, stick your wire through and around it, and heatshrink it.
Reversible, and the spring tension, heatshrink, and loop around make a pretty secure connection..
I recently undid that to my climate control plug because I finally found the 'right' plug.
The wire is thicker than a pin, so the receptacle might lose some tension if going back to pins.
I pryed on them a little to tighten them up before plugging it in.
justinakay79
