blackironarmory
- Joined
- Jan 23, 2016
- Posts
- 15
- Reaction score
- 0
Hi Another newbie here with what seems to be a somewhat common issue... 2006 Denali with Air Auto Ride. Compressor used to kick in all the time so I assumed bad shocks and was really ******* the electrical/charging system. During the first 5 minutes of driving, intermittently, the volt meter would drop from 14+ down to about 13 or less. The engine would struggle and of course the lights would dim. If the kids weren't screaming, or the music wasn't turned up you could hear the compressor kick on at the same time. If at an idle, say at a drive through, it almost killed the engine when the compressor kicked on. To be clear, I've had no warning lights or indications of a problem from the vehicle at all...
Assumed it was the air bladders on the shocks so I ordered a new pair. This is my wife's car so she doesn't really pay attention to issues like this like I would. I drive it with the family on the weekends which is when i notice the little problems. New shocks arrived on Wednesday. We took the car out last night, however I never heard the compressor kick on once. The electrical issues remained (dim lights and voltage drops) however so work from the compressor that I could tell. Same thing this morning as I drove the car to the shop I work (farm equipment) at to do some before hours repair.
Swapped the new shocks in to no avail and yes they are air shocks with sensors and all. When I disconnected the air lines off the old shocks, there was no air pressure released so that confirms my original diagnosis, however now I get no joy from the system. Found after a quick google search the three fuses and main relay that is supposed to control the system and everything seemed to check out. Grabbed one of the better electrical diagnostic techs we had and he did a quick check over the fuses and relay. Relay clicks over but still no signal to the compressor. The one thing we did not get a chance to do was drop the compressor out and bench test due to time constraints.
The compressor remains disconnected from the system and I still did not get any warning lights, however, I did notice on the drive home, there were no voltage issues. I want to keep the air ride as we have a ski boat and a travel trailer so maintaining this vehicle for towing purposes would be ideal.
Curious if A: The compressor is shot from working so hard over the last few months. Its the cold wet rainy season here, could the moisture drawn in from constant work caused a failure?
B: Is it a sensor issue? Would that not have thrown a code like so many people talk about?
C: Screw it all and install a passive air system where you fill the shocks with an external compressor and Schrader valve?
Thanks in advance!
Thanks in advance!
