Anyone replaced one of the front parking sensors?
robgreg75
One of mine must have gotten a direct rock hit and no longer works so none of the front parking sensors work now. Dealer said it was damage so not a free fix.
SSGUNNER
Typical stealership. Id like to know as well.
WalleyeMikeIII
Sunny and Snowy Minnesota
Should be covered by your comprehensive insurance if you hit a flying object — same as hitting a deer. Key is, when you file the claim, you hit an airborne object, not something that hit the ground..
R32driver
They're held in with 2 clips. I had one pop loose when I swapped out my grill. I'll bet you could get to the outboard ones by pulling back the fender liner but not sure about the ones more toward the middle. The faces are painted body color so make sure you get one that's the correct color
Yizzo88
