Anyone put N-FAB step bars on a NBS Yukon?
SRTH8R
Littleton, CO
Just unboxed these N-Fab side steps. They don't line up with anything. Anyone put these on and have a couple pics? Maybe they are miss boxed. I would assume "bolt on" would mean just that, not drill holes in the body then bolt them on. Any help is appreciated. Thanks.
Mister H12
Undercover Racecar
West Tennessee
First thing I'd do is check part numbers. I'm sure they make the same thing for many makes and models, so just going by length wont help.. Bolt on definitely means just that.
SRTH8R
SRTH8R
Littleton, CO
Well I found guys on gmfullsize that put them on. For the NBS you have to drill through the pinch weld. Nnbs is all bolt on. Guess I expected a lot more. Heaven forbid they use one of the like 16 holes that are from the factory.
SRTH8R
SRTH8R
Littleton, CO
Bit the bullet and drilled 3 holes for each side. It was a bigger deal in my head than in real life. Will look better once the lift is on.
SRTH8R
SRTH8R
Littleton, CO
Not really. You could cut the mount and weld it lower. But there is another bracket that ( not listed in the instructions, found on gmfullsize) you could also mount to the floor for added stability. I'm a fat kid and they don't move much, so I don't see a need for it. Supposedly will hold 475 as mounted.
jackal78
