ANOTHER HID QUESTION
KEVIN GARRETT
newbie here, why does everyone recommend only running HID'S in projectors and not standard headlight housings?
ezdaar
Chat Troll
Redneck central, Aka Houston
Because they look like this as on coming traffic. This typre of shit makes me want to do horrible things to those drivers.
If I wanted to look into the glare of a thousand suns, I would use a telescope to "sun watch".
Just looking at this picture is pissing me off!
1348470d1391115596-lightmare-you-using-hids-halogen-reflector-housing-please-dont-do-clipboard01.jpg
1141709d1362486322-lightmare-you-using-hids-halogen-reflector-housing-please-dont-do-2.jpg
K
KEVIN GARRETT
OK to be more specific I'm looking for educated answers. If I cared what it looked like to others then I would stay with stock and as far as beam output if you actually know anything about cars you would realize that proper aim is more important. I simply asked if there was a decent benifit because I personally hate the look of projectors in trucks. Thanks for the input.
seven9st surfer
Milton, FL
I was about to post a few links, but then I realized Nathan covered them all in his first link. If you're really after an educated answer, please take the time to read the post, along with the links. There's a lot of great info there on why it's illegal (and incredibly annoying/dangerous to other drivers).
Please don't put a PnP HID kit in your reflectors.
chevync
North Carolina
Neighbor has 10k in his duramax with stock housing. I go out every morning taking my daughter to the bus stop, he blinds me everytime! I think it looks like sh*t in stock housing, if you want hids do it the right way and use projectors.
nharkey85
Alabama
Because they look like this as on coming traffic. This typre of shit makes me want to do horrible things to those drivers.]
110% behind you on this. And the exact reason I'm still on standard housings/bulbs. I don't even run high beams because the glare off of road signs kills me from my own lights.
Sent from my SAMSUNG-SM-G920A using Tapatalk
YukonXL04
The Riverboat
Arlington, TX
Man I want to run that guy off the road...
So your saying you don't care if you blind other drivers or if they blind you while your driving?
Simply reason for why? Much better light output and visibility without blinding other drivers.
Also there is no proper aim when hids are in halogen reflectors... sorry.
My hid projectors
View media item 23981
Low beam.
K
KEVIN GARRETT
ok so after looking at them in detail how many of you have problems with the DEPO projectors bouncing around at night ? it seems to me that this is a very common problem for these and for that price it shouldn't be. if you have this problem how did you fix it?
seven9st surfer
Milton, FL
I don't have the Depos, but I know people have used ping pong balls shoved down there to stiffen the mounts up a little bit. Found this on the site, I think it's Fosscore's:
K
KEVIN GARRETT
DOES ANYONE HAVE PICS OF A WHITE HOE WITH BLACK DEPO'S AND BUMBERS? AND ONE WITH CHROME DEPO'S AND BUMPERS? I'M TRYING TO DECIDE WHAT LOOKS BETTER.
ezdaar
Chat Troll
Simple way to stop headlight bounce.
Get a drinking straw,
Cut 2" off,
Cut length wise down the 2" section,
Trim off 1/8" down the straw lengthwise,
Roll up the straw so it overlaps its self lengthwise,
Slide it into the holes the pins go through,
Install pin.
No more bounce.
Do this for which ever mounting holes are worn out.
K
KEVIN GARRETT
My depos (black) don't bounce at all, they are rock solid.
Good. I have mine ordered and hopefully will install before Christmas. With the HID's I'm hoping I get a solid set also. All the reviews I've read are good with mixed reaction to the shaking.
jxw004
Don't know where you are located, In Texas they are illegal unless car came equipped with them. You can run LEDs and be just fine (had my set in highs and lows for almost a year). The reason people want you to run projectors is to not blind oncoming traffic, every time this happens to me I return the favor with my light bar...
K
KEVIN GARRETT
ok so i have finally gotten the depo projectors installed with the kensun HID 6500 kit. so far after a few nights of driving i LOVE them. one thing that i have noticed is that on the pass. side there appears to be a dark space in the middle of the beam. im thinking that maybe the ignitor rod is on the bottom instead of the top? has anyone else had this issue?
also how does everyone aim theirs? i origainally did mine by state law spec however i changed that slightly last night because the cutoff line was not even. i set the line to level with my hood at about 25 feet from a wall but it seemed like at times i was still shining into other cars?
HeavyHoe03
