Amber DRL Options
STORMIN08
for a 2022-2023 model year, does anyone know of or have link to a way to have AMBER DRL ???
i know i have seen some like this, but havent found anyone discussing it or having done it
Toasty
you'd have to rewire the LED's, amber is used for the turn signals, white for the DRL's
STORMIN08
STORMIN08
Thats why i have asked, i am 99% certain i have seen a couple that have this done.
i even tried to turn around a follow one to see what was done.
may have to look into repinning or better would be a jumper and diode to achieve this.
anyone seen a wiring diagram for these years ?
WalleyeMikeIII
Sunny and Snowy Minnesota
You can check the GM upfitter site.
But, you will likely be most disappointed.
The headlamp is a self contained module (assuming there is a small PCBA w/ some controls on it). Has Power , GND, and It receives a turn signal signal via the BCM and then Lighting Control Module for the turn signal, and it receives a signal from the same control modules for DRL, High, and Low beams. So…it’s not crystal clear how one would wire it up to flash Amber when the turn signal is on and be solid Amber when the call for DRL is sent.
Fast_AT4
RWM +1
SW Florida
I must say @WalleyeMikeIII that I am always impressed with your detailed replies. You are truly a valued Member here.
WalleyeMikeIII
Awe…thanks @Fast_AT4.
Before I replied, I looked at the upfitter site schematics, and wrote that reply based on what I saw. I’m not saying someone couldn’t make it happen; but it’s going to take some engineering and some trial and error.
These rigs aren’t your old school 12V supply through a relay with a Flasher (RC circuit) setup. It’s all solid state stuff inside Body Control Modules and Lighting Control Modules…not your dad’s Oldsmobile .
STORMIN08
STORMIN08
well, that may back burner awhile...not really worth the effort...but for sure would look alot better with an amber glow all the time
ThatGMguy
AZPatriot1963
