alternator
Tahoe03mm
Puyallup, WA
this is semi-performance/audio question.... they have 05 oem 145 amp alternator on ebay. I'm just wondering is this going to help with the idle output if I swap this out. I thinking of getting this http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200399130158&ssPageName=STRK:MEWAX:IT#ht_500wt_956 to help with amplifier draw from the subs and when I switch to e-fans
oh probably another important questions... is there any reason this wouldn't fit an 03? ie. mount different, belt size, connector difference
blueflamed03
Oklahoma
are you sure yours doesn't already have a 145? Mine does.
It really doesn't help at idle, just off idle mostly.
Are you needeing more amperage for aftermarket goodies?
Tahoe03mm
Tahoe03mm
Puyallup, WA
i think the one that's on mine is only 105 amp.. not 100% sure though..
yeah I want to run e-fans and be able to bump my subs without having to worry about walking cuz my voltage meter looks like a tac :)
blueflamed03
Oklahoma
go out and look at the lines on your glovebox, write down all the K codes and run them.
Here are some
8A7, KG8 - 130 amp
8A3, KW2 - 124 amp
8A5, 8C0, K98, KG9 - 140 amp
8C6, KG3 - 145 amp
8C7, KG4, KG5 - 150 amp
8W5, 8X5, K61, K62, K65 - 105 amp
8Z3, 8Z4, K60 - 100 amp
K09 - 120 amp
K63 - 110 amp
KG7 - 125 amp
KW1 - 160 amp
KW3 - 135 amp
KW7 - 170 amp
KW9 - 190 amp
KYU - 200 amp
Eickybobby5050
