Alternator Weirdness! Help!
bazooka
Conroe, Tx
So, I was coming home from a trip to Kentucky on Christmas Eve and my "battery not charging" light comes on my '03 Hoe, then off, then on, off, on, etc which I guess is normal if the alternator isnt working. It was after dark, so I had no choice but to run the lights and after a while a could see that the voltage meter was slowly dropping so I found a Walmart just before the 6pm closing and bought their best battery and a charger in hopes of making it home. Well when I got back to the truck and cranked it, the light didnt come back on and it was showing 14 volts on the gauge....dayum whats up with that I thought? So I drove it for probably 30 minutes with no "battery not charging" light before it started again.
It eventually ran the battery down so I stopped and changed the battery to the new one which Im sure didnt have a really full charge. This got me closer to home, but not wanting to get stranded in nowhere land on Christmas Eve night, I stopped and got a motel room before the new battery completely died. I charged my old battery overnight (its only 8 months old and its a very good 1100 CCA battery) and charged the new one for about 3 hours the next morning and struck out again. This time the warning light stayed on and I had to swap batteries one more time to get home. What I am wondering is, do I have a loose connection somewhere, or some other problem than a totally bad alternator??
GMT800 2005 Tahoe Z71
Navy Supporting Member
Your alternator is going bad. Before it goes out completely it can do these types of things intermittently. Likely the diode trio is starting to fail. If a diode goes completely bad it can do a drain on the system when engine is shut off, like leaving the headlights on. I would change the alternator.
TxDrewski
Potomac,MT
Check the connection on the Positive Jump Box, there is a nut that holds the wires down. It backs off and your alt stops charging. Had the exact same thing happen to me.
---------- Post added at 06:32 PM ---------- Previous post was at 06:31 PM ----------
Im in lufkin not too far from you, gimme a call I can explain it better
9362259669
bazooka
bazooka
Conroe, Tx
Andrew,
Thanks for the call buddy! I checked the connection and it seems tight, didnt put a wrench to it yet, but to wiggle it, it does appear its tight. Guess I will have to have the alternator checked.
TxDrewski
Potomac,MT
Andrew,
Damn that sucks, sorry to here that. Let me know how the bench test goes thats so odd.
D Rollins
