Alternator recomendation needed
cybertek
South Carolina
I need to replace the alternator in my 06 Denali. I may beef up the audio system a little in the future but nothing serious.
What size, brand do you recommend? Please post links if you can.
Thanks!
GMT800 2005 Tahoe Z71
Navy Supporting Member
If you do the audio beef up make sure to try and add an additional battery and use lower number/bigger around/less resistance gauge wire and check the alternator case for the amp output and find a bigger output with same case that fits. Some shops can rebuild your alt for more output.
cybertek
cybertek
South Carolina
DC Power
Has anyone used this alternator?
185 Amp OEM GM High Output Alternator from DC Power Engineering
https://www.dcpowerinc.com/fit/GMC~Yukon-XL~2006~6.0L-V8/8237-185-oem.html#tab-product_overview
Thanks!
clandr1
Dallas/Fort Worth, Texas
I'm a big fan of Bosch. If they have one that is high output, it would probably serve you well. I replaced the alternator in my '89 Jimmy three or four years ago and the Bosch is still going strong.
Mister H12
Undercover Racecar
West Tennessee
If you're not planning on doing big audio or accessories and stuff.. dont spend $600 on an alternator.
Drewphil
