Airbag light woes code B1001
CBIII
Hey again gang,
After my ridiculous seat heater inop/battery drain situation last winter, I have since had an airbag light that was not there previously. I've replaced both sensors with brand new ones and no change. I've also checked the connections under the passenger seat but didn't see anything.. I had the BCM swapped at a dealership and they can't tell me what they did and didn't do without recharging me a diag fee. I know there's a bulletin out there and comments in regards to the BCM needing the correct VIN, but I can't figure out how to confirm/do that. I bought a Bluedriver hoping it'd work but it doesn't seem to.
When I clear the light, it stays gone until the truck is restarted and it comes right back. I REALLY think it's the BCM but I can't get a single ******* person in my area to understand what it is that I need and those that do don't have a bidirectional tool. Aside from a Tech 2/clone, what are my options? ideally cheaper the better.
I've looked at the tech2 clones but it seems like there's a lot of room for error in compiling/configuring it all. Any tips?
mikez71
I know this is old, did you ever find a solution?
I'm in the same boat after swapping BCM's. ('02 BCM in my '05)
Apparently the older BCM's need a manual SDM sync.. (SPS programming?)
However it sounds like later models do not..
Ridiculous that the dealer would not handle it after they replaced your BCM!
Charlie21ny
