Air Suspension v. Longer Wheelbase
homesick
The Best Me I Can Be
Navy Air Force
From Perplexity...
GM RPO code Z55 refers to GM’s Autoride suspension package, a computer-controlled, load-leveling system that uses electronically controlled shocks and rear air suspension to adjust ride height and damping. It’s commonly associated with GM trucks and SUVs like Tahoe, Yukon, Suburban, and Escalade models.
What it means​
  • Electronic damping: The shocks can stiffen or soften based on road and driving conditions.
  • Load leveling: The rear suspension can self-level when the vehicle is loaded with cargo or passengers.
  • RPO label code: GM lists these options on the factory option sticker, often in the glove box or similar location.
does it include mag ride
No. Z55 is Autoride, while GM’s Mag Ride/MagneRide is typically Z95. Z55 uses computer-controlled shocks and load-leveling, but it is a different suspension system from MagneRide.
How to tell them apart​
  • Z55 = Autoride.
  • Z95 = MagneRide.
  • If you’re checking a GM option sticker, look for Z55 for Autoride and Z95 for MagneRide.
Z55, Autoride, was the first electronic suspension, using metering valves inside the shocks that were electronically controlled to adjust the shock's stiffness. The response time for the shocks to adjust stiffness was 20 ms. And, yes, it also had rear air shocks (in addition to the electronic dampening) to keep the truck level, regardless of internal loading or external towing.
Z95, Magneride, was the next generation of electronic suspension, using an electronically reactive hydraulic shock fluid inside the shocks that was electronically controlled to adjust the shock's stiffness. The response time for the shocks to adjust stiffness was 4 ms., a dramatic improvement in response time over the previous generation. And, yes, it also had rear air shocks (in addition to the electronic dampening) to keep the truck level, regardless on internal loading or external towing.
Newer trucks still maintain the Magneride electronic suspension option, but now there are options available for all 4 shocks to be air assisted to raise and lower the entire truck, in addition to automatic leveling.
I've had both the short and longer wheel base trucks, and I prefer the longer wheel base for a number of reasons that meet my personal needs.
P
Protect1989
Been pricing out my 26 Tahoe as I go back and forth on this decision. Figured I’d share some numbers
2026 Z71, 5.3L, fully loaded, 5k miles, 83k original sticker, purchased 12/25
One dealership offered me $72k
Carmax offered me $61k
kikeap
