Aftermarket Brakes
07NALI
I have an 07 Denali. What are the options and what does everyone recommend?
I know about Wilwood but dont want to spend 5 grand on brakes. Thanks
They'll be sitting behind 22"s
06xl
MD
You can do the front for 2500 (wilwood) an keep stock rear or upgrade rotors and pads.Thats what these helpful fellas advised me to do:) (if you dont have 5k to blow)but if your not running aftermarket rims 22,24 and dont plan on towing I would stay stock just change to drilled/slotted or slotted rotors an go with a good pad green stuff,yellow stuff, stop tech tow,haul...also stop tech has a kit drilled/slotted rotors all 4 and (8) pads for around 320.00 on autoanything.com an you can change the lines to stainless steel I think that would give you a noticeable difference but won't hurt your pockets.
edgaranah1
Corona California
^^this guy knows his stuff.
Sent from my BlackBerry 8530 using Tapatalk
yates ™
Resident Apple hater
Iowa
I honestly cannot figure out why everyone thinks you need a big brake kit if you run 22"+ wheels. I run 24's and tow and have not had an issue as well as many others I know. I will agree that they will probably wear out faster but many things can factor into that.
07NALI
Im doing it more for looks honestly, although the performance is definitely a huge plus.
**Waiting for the paint your calipers comment :gayflag:
Modded
That Guy
Because a lot of people just don't know what they are talking about and think anything above 22s weigh 1000 pounds. My black 26s with tires weigh in at 110 pounds. A whole 15 pounds more than stock. The difference in braking is so small that I barely notice it.
Spending $1500+ on big brake kits that probably cost more than the cheap wheels that are put on these SUVs so much makes no sense at all.....
Not like the SUV is supercharged or anything.
badblu97
I just picked up an 08 LTZ Hoe, but to get her, I sold an 07 LT Silverado Crew. I had 24's and towed fairly regularly. The truck had 52k on the clock, and around 50 of those on the big wheels. Just before I sold it, I put cross drilled and slotted rotors and ceramic pads, mostly for looks. I did not notice a difference, but when I took the stock pads off, they had about 50% pad left. Heres a pic of the wheels with the new brakes behind them, and the new LTZ!!
06xl
MD
I've noticeable horrible/scary brake fade with fresh stock set-up on factory rims plenty of times and don't add a 400lbs (empty) open trailer =not a fun ride in my xl .so there is reason for bigger brakes in my situation especially when I'm carrying precious cargo.plus 16 inch rotors and a huge ass caliper sitting behind 22,24,26 looks hard as shit Vs a 12inch rotor looks like someone did a half ass job IMO .go hard or go home
yates ™
Iowa
:word:
I will agree to the statement that they look better but can't not to it being a half ass job. In that logic then towing anything where the back end sags is unsafe and half ass. If you noticed brake fade on a new stock setup on factory rims then you have other problems with your brakes then needing larger brakes. Also since the 07+ have larger factory brakes then previous gens then anything not 07+ is not safe to tow or run a wheel larger then 16" wheel. Like I said before I will totally agree that they do look better but the logic that you need them is sadly flawed,
06xl
MD
:word:
To each his own bro.. I'm not satisfied with the factory set-up at all neither is the wife an with 5 kids in the rear I did whats best for mine as far as the OP I just put out suggestion to his ?and I'm not saying that you can't tow or run large wheels on a NBS at all I just don't like how MINE feels with larger wheels and a trailer in tow.
AZSCTACO
Phoenix, AZ
Since you asked for a recommendation on what to get and not ask for a debate...here is mine:
I got the Powerstop kit and have nothing but great things to say about them.
http://www.powerstop.com/products
Oh yeah.....I've had 22's since day 1 on mine and the stock rotors/pads lasted 100k with no issues at all. This upgrade, compared to stock is definitely worth it. I can't see spending 3-5k for a big brake upgrade. I have precious cargo like others....I just don't drive like a douche and tailgate. If stopping in 30 feet from 60-0 mph....I probably wouldn't have bought a tank like a Tahoe.
06xl
MD
Thank you the man asked what do we recommend ?? And I clearly gave him my opinion on what I think is best.
Keanen55
HOUSTON, TX
That's the kit I went with! Looks good and a slight improvement on the stopping, and didn't have to re-fi the house to pay for them!
AdrienR
