Adjusting Headlights
Chevyrider619
Virginia Beach
Ok new headlights are on now..So now my question is,does anyone know how to adjust them?? I was looking at the manual but they say to take it to the shop,forget all that..Any help would be appreciated:hmm::think::think:
riviera rider
i havent messed with mine yet but there should be some sort of screw that either moves in or out to position the headlight angle up or down you mite have to mess with it a bit to get it where you like it, but ill look at mine tomorrow and let you know for sure
haks310
Got LEDs?
SoCal
Each headlight has two screws, either a Phillips head or a T15 hex, IIRC. One for up and down, other for side to side. They are hard to miss.
"350Vortec"
*Tahoeless, For now*
Careful, On older trucks these adjusters tend to break VERY easily.
DJTricky
Banned
Robbinsdale MN
hahaha here you go man, right out of the GM mechanics book if you dont have the headlight aimers
1 - park your truck 25 feet back from a wall ( has to be exactly 90 degrees)
2 - measure from the center of the headlight (the little O in the center of the low beam lense)
3 - take that measurement to the wall and mark 4 inches lower then the hight of the headlight.
4 - measure from the center of your truck to the same O on the lense and transfer that line on to the wall also.
5 - adjust the hot spot of the light to the cross section and your done
ravingmadman
Chief Knuckle Buster
Greater Seattle
I broke the crap out of mine, and they're new. The adjustment screws are accessed from the top. There's a hole in the top of the grill where you can get a phillip's or torx wrench down into. The bolt turns a worm gear that pushes the bottom of the light in or out, and that's what breaks. It's a little 4-pronged plastic failure of engineering on GM's part. Oh well.
riviera rider
im going to have to be carefull messing with my new headlight setup then
Chevyrider619
Chevyrider619
Virginia Beach
I was checking the screws on the headlights,i'll do them tonight...They have adjustment but for a stock tahoe not lifted so i have my headlights pointing down to low..
preshus
washington,IN
which screw is for up down and left to right
---------- Post added at 02:29 PM ---------- Previous post was at 02:28 PM ----------
google won't tell me that one
NOVAhoe
Manassas, VA
the one for up and down is the inner most screw, closest to the hood latch, the one next to the fender is for left and right....obviously haha
mtglick
