Added new shoes to the hoe and now rubbing HELP
grnrpr68
Davenport IA
hey whats up guys i got my 2wd hoe about 1 month ago and the guy told me it was lowered 6in and it is very low..but my questions is i just put a set off 22's on it 2day and for some reason im rubbing in the right front corner on the fender pretty good...i measured all corners and got 28 1/4 on both rears and the right front but i got lil more 28 3/4 on the left front..im rubbing on the right front thinking spring but not for sure...it has bilstien shocks on all 4 corners flip kit and notch kit in the rear drop spindles and coils in the front not for sure stumping me can someone help out.....thinking about doing a 3-5 lowering kit so i shouldnt have any problems but would like to keep it lowered thanks for any input
---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ----------
foreverfalcon40
Heat up the plastic on the inner fender and push. or just cut the part out
if it it the actual fender then get it rolled.
grnrpr68
grnrpr68
Davenport IA
yes its lowered the guy said there was 2in lower spindles on it it is rubbing on the fender and they are already rolled and the rims are player 712's just missing the black feet on the edges and the BFH is coming next
Limited
Grnrpr68: Whats'up man, to answer your question, I have a 2" drop front and rear, but I believe the tahoe limiteds were lowered already from the factory about 1" to 1.5 so it's more like a 3-3.5 drop. (That is if what I read was correct). Either way, I rolled my fenders due to them cutting into my tires, and as far as the inner fender wells, ours are metal so you may have to beat them in or have them tubbed. My 24's rub the inner fender well on large bumps so I will be gettin my tubbed sometime in the near future. I's suggest, first rolling the fender lips and after that maybe beat in the INWs with a hammer or just have them tubbed. Hope that helps
grnrpr68
grnrpr68
Davenport IA
mikeyboy thanks still gotta lot of work to do yet..........i spoke with tony at DJM and we might have figured it out..he is sayin that my drop spindles might have brought the tire out a lil bit 1/4 in and now on a bump dip i have a rub on the fender so hes looking into what i can do
grnrpr68
grnrpr68
Davenport IA
well found out its the drop spindles doing it so i am goin to order new ones and just put stocks back on for now i need to finish well start getting the system install going got a lotta shit goin in the hoe so 22's off for now and rolling stocks for lil while oh well
grnrpr68
grnrpr68
Davenport IA
2in belltech drop spindles i can change the rims and get a differnet offset and make them work but i am goin to raise the truck 2in so i can ride on 24's and have the stereo setup in it but atomic i dont know make me an offer
grnrpr68
grnrpr68
Davenport IA
stocks are back on and new spindles are in waiting for rear parts to get here hopefully in next couple days then will post new pics with it raised 2" and rims put back on thanks to all for the comments
ASG-MikeS
