Hello all,
Been lurking here for a while reading posts, can usually find my answer, this time I am stumped and would appreciate any help. Here goes
99 Yukon Denali. I have multiple problems in the last month but I want to stick with this one. I have replaced the started several times and each time I replace the starter its because of a broken nose cone on the starter. I get a lot of grinding on the starts and eventually the flywheel kicks back so ******* the starter that it breaks the nose cone. Had it scanned at autozone and it throws a lot of codes(Crank sensor, Cam sensor, etc) could I be crazy and maybe its just the distributor/timing is out of adjustment, I have replaced the crankshaft position sensor and no luck. THANKS in advance for any help or opinions. also if you need more info just ask. Thanks
