500+ rwhp out of a 5.3?
Deadbaffy
As the title says, I’m trying to get over 500 to the wheels NA. Is it possible with a 5.3? Or should I just start looking for a 6.0? I’m at full bolt ons right now and I don’t want to do heads and cam if I’m not gonna reach my goal. If I can just get close to 500 I’d be happy with that. Mods so far are Banks intake, 1 7/8 pace setter long tubes, mbrp 3” axle back exhaust, tbss intake, and just to hold it over until I do the head cam swap - a Holley fashpaq tuner. Will be dyno tuned once I do the cam, if any of that helps. Am I missing anything before I do h/c? Also getting a set of ls1 heads milled, ported, & polished for it.
Deadbaffy
Deadbaffy
Also any suggestions for what cam would be appreciated. I daily this car but I don’t care about anything but a reliable 500 hp
Trey Hardy
My buddy put down good numbers in his 5.3 with a stage 4 custom grind cam from Texas speed he used it in his 5.3 and his 6.0 and it ripped
Nothing special stock bottom end with ported 243 heads hollow valve stems with pac springs and the custom cam corvette intake with a cold air intake and a ported throttle body but paired with the 4.56 gears and a built transmission she would just naturally blow the tires off her 1st 2nd chirping 3rd probably around the 400-450hp or so to the wheels
strutaeng
Dallas, Texas
500 HP Rear wheels NA? Probably not, unless you want to rev it to like the 7k RPM range? IDK
500 flywheel, probably, yes. But still you'd be up there in the high range RPM to get there.
Why don't you tell us what are your goals with the truck? Daily driver or dedicated track rig? Things like tire size, gear ratio and torque converter stall speed all play a role in working together. What transmission are you running? 10 bolt rear end?
What is your budget? 6.0 is going to get to those number easier, but you have other options such as boring your 5.3 to 5.7 (iron block LS1) or even an LS383. You can do similar to the 6.0, of course. All you need is money...
Mudsport96
40.923,-89.488. Illinois
Is it possible? Yeah but it is going to take a pile of cash. And then your 4l60e is going to leave the chat in a hurry. So there is more money.
The amount you would spend to get an NA 500 wheel is going to be a fair bit more than if you did a max speeding turbo kit and left the 5.3 bone stock.
14psi on a bone stock LM7/L59 is 600 crank. So even if you lost 100 hp in the drivetrain you have your 500 wheel. I don't have the time at the moment to go find the video. But Richard Holdener did a 400/500/600 hp step video for a 5.3.... and while you can get there NA, it is a whole lot of work and money.
Deadbaffy
Deadbaffy
It’s a daily driver and at most I can have it down for a week. My budget is whatever, as long as it stays reliable, I don’t care. I have a stock 4l60 with 3.73 gears and stock converter at the moment. Tires are 275/55, so about 32 in. Was going to go 4.10 or 4.56 with a 3k stall, and obviously beef up the 60 but would like to tackle all of it at once with h/c, so at the moment I’m just getting the parts together. Once I know what cam i want I was going to get everything else coming. Not opposed to a supercharger down the line either, but just want a fun, quick daily out of it that isn’t constantly breaking. Kind of seeing what others have done or wish they would have done before committing to one thing or another. Not my first time building something but first time doing a truck and an ls so figured experience from others input would be better than winging it.
Deadbaffy
Deadbaffy
thank you. I’m trying to just get as close as I can, maybe a blower in the future, but a good cam combo and what others wish they would have done/have done when they did a 5.3 build. Id rather not swap it to a 6.0 but if I find one cheap, who knows. Just looking for advice from people who have done ls trucks since this is my first ls and first truck I’m building.
probably wise to build the rear end and transmission first, then do the engine. Otherwise your gonna break it and have unexpected down time
I recomend the eaton detroit tru-trac
then for the transmission tell the builder what your plans are and they can build it accordingly and do not go to the cheapest bidder in town, that's just asking for it.
Deadbaffy
Deadbaffy
I am the builder. That’s why I’m on here for guidance before I just slap whatever in it. But you’re right, those are things I’m already worried about breaking as it currently sits. I was looking at the tru-trac already so I think I’ll go ahead and get that now.
ya that's the best one out there, never heard of anything better
if you are going to be buidling the transmission yourself you might try and get info from @NickTransmissions
strutaeng
Dallas, Texas
It’s definitely in consideration
500 RWHP is like 600HP (assuming a 20% loss through drive line) at the flywheel. That's a lot.
That's going to be a very expensive 4L60e build (nearly all internal parts are going to be Sonnax $$$) and still may not live a long life.
OR
A pretty much stock 4L80e will laugh at your engine's power. If you look around, no need for the Transgo HD-2; you can accomplish the same with like $15 in parts: dual-fed direct and HD intermediate snap ring. Just freshen up a good core and off you go.
And before someone mentions the 4L80e is gonna be slower due to the numerically lower first gear ratio, look here: https://ls1tech.com/forums/automatic-transmission/1712527-power-loss-when-swapping-4l80e-4l60e.html
Traction is probably going to be your next challenge.
Deadbaffy
Deadbaffy
OR
Those are about the numbers I’m wanting too I’ll daily on semis if it’s too bad.
Mudsport96
Okay, well the parts and tuning required for you current goals are going to be at least a week. What you should do before anything else, is get a ( quality) 2800 to 3000 stall converter. That will help even a stock 5.3 and can be used behind a modified one.
Yeah.... 500whp in a tahoe with a 60e is reliable as long as you rarely get on it. To be reliable you need an 80e.
Go straight to 4.56s if you don't do a lot of highway driving. You are trying to move a tank, and higher number gears make is seem like you have more power.
Your best bang for the buck in my opinion is the following in order.
Good posi with 4.56 gears
Quality 3000 stall converter.
Drive for a bit and see how it feels.
BTR lower lift no springs required Truck Norris cam ( will help with reliability)
This should be a pretty good package. And in reality, have more midrange usable power than a 600 crank/500 wheel engine ( 5.3 liter) in the same truck. Which means, it will be faster to accelerate.
clogan2
What about a supercharger/intercooler with a tune? I've got the Roush kit on my F150...no idea what's available for Chevy/GM, but a S/C is FUN!
fozzi58
North Jersey
I blew up my G80 rear in my 17 Burb and just had it completely rebuilt. Yukon axles, ring/pin, bearings etc with an Eaton Truetrac carrier and replaced the factory 3.08's with 4.10s. Also had the tubes welded for added strength.
Its a daily driver with a Whipple, Kooks LTHs, and some other goodies but haven't done anything to the motor yet. I haven't dyno'd it yet either but have to be guessing about 550hp at the crank so roughly 400hp at the tire maybe? Its been pretty reliable. I swapped out the factory stall for a Circle D triple disc in my 6L80 and even at 110k miles, there isn't a speck of metal in my trans fluid. Whipple has been on since 60k miles.
I 1/4 mile the truck and run autocross with is as well. She's been very reliable outside of some self inflicted wounds but otherwise rock solid as a daily and I have surprised the shit out of some unsuspecting mustangs.
You are never going to hit 500rwhp in an NA 5.3 unless you do forged internals, roller everything, and run e85. You need to go FI to reach those numbers on a "stock-ish" motor. But once you do the motor, 700-800 with a power added is possible on the 5.3.
JamesinAbilene
