_bcstrout
super interested in doing the 5.3 swap in my 96 Tahoe. does anybody know where or how much would a wiring harness cost and where I could buy one? new to this idea. any advice could help.
You've got a couple options, one is to repin the original harness. By doing that you'll solder in the injector wiring (colors all match the wires inside the big plug. you'll also want to get the coil harness from the LS (hopefully all the way back to the PCM to save yourself about 2 hours worth of tracing wires and soldering) if you don't completely unloom it like I did you'll need to extend the TPS and IAC wiring, and repin the CKP and CMP sensors and combine the wiring from the IAT and MAF sensors into the LS style maf connector.
Another option is to use the entire LS harness, and connect the ground and power to the old fuse box, then you'll just need to move a few pins over from the old computer but you'll be left with a lot of extra wiring under the hood, not clean enough for my liking.
the third option is to buy a complete harness from someone like Painless harness's. That's probably the easiest but also the most expensive.
---------- Post added at 01:47 PM ---------- Previous post was at 01:07 PM ----------
I'm going to try to get in touch with Lextech from the GMT400 forums. He's the one that developed the swap pinout that I and a lot of others use. It would be nice to have him on here as these trucks age and more people get interested in a swap. I can't provide the diagram he gave me though at his request.
