33x12 or 32x11
woketradr
What are the largest tires i can put on a 2019 tahoe, with 2 inch level, and 2 inch wheel spacers with no rub?
Trey Hardy
Stock wheels I’d say a 33/12.50 without the 2” spacers you could clear 35s with a 3-3.5” leveling kit but will probably rub the tire on the control arm if their aftermarket
woketradr
woketradr
Okay thanks, I know 33 x 12.5 fit without spacers, but I wasn't sure how it would go with spacers.
If i can get away with a 2 in level 2in spacers and 33s that would be nice.
Cryptothedog
I have 33 x 11ish (not sure the exact width, I’d have to do the tire size conversion to figure it out) with a 3 1/2” lift and 1” spacers on stock wheels and I get a little rubbing with wheels cranked and im backing out of my driveway or something and hit a dip or back off a curb. Basically only a circumstance where the wheels are cranked and you are putting stress on the suspension.
I didn’t have any rubbing without the spacers, but I had to put the spacers on or I got rubbing on my control arms whith the wheels cranked.
tsouth32
How tall is your front sitting at the top of the fender? I put a 3” on mine and it’s sitting at 41”
Cryptothedog
Mine is also 41” up front. My tire size is LT275/70 R18 I looked back on my order though and I actually have 1.25” spacers not 1” like I stated previously
Cut Wagon
Senior Member
South La.
You added 3” and get 41” ?
Mine is
Front 38” 1/8
Rear 38” 3/8
I thought it was leveled a bit. Not sure if what I have is stock?
I’m on 285/65/18 currently
john1989
