305/40R22 or 305/45R22
guso
hi,
I currently have a 2011 Yukon Denali XL with 285/45R22's. I am pretty sure I can move into the 305/40's but can I put 305/45's without rubbing?
soulsea
Bar
Even the 305/40s will rub an intsy bit, 45s will rub a LOT.
G
guso
Thankyou.
In your opinion you wouldn't even go with the 40"s?
THE YETI
Director of Operations
South FL
Lino, 40s are good to go. Slight rubbing but usually it goes away.
soulsea
Bar
305/40 are actually visually the perfect size, the rub is very minor and rarely experienced. They are slightly stiffer than the 285/45s, but if you don't mind that then go for it. Having had both sizes I'll probably go with the 305/40s next time I need a new set.
johnsonwillie199
