3.5" RC Lift and which Bilsteins
Ziggyboy
Just ordered the lift for my 09 tahoe 4wd and wanted to know which bilstein for the rear can I run. I asked RC and they said 16 collapsed and 26 extended. Can I just order a set that is a tad bit larger than that on bilsteins website that's specific to the tahoe? Plan on getting the bilstein struts up front too.
Thanks in advance guys!
Sent from my SM-G960U using Tapatalk
HiHoeSilver
Away!
Chicago
The 5100s are adjustable. The specs on the ones in this post are about 16"-26" in the rear.
https://www.tahoeyukonforum.com/threads/lift-with-bilstein-shocks.94996/#post-1136841
PG01
Up here to the right
Yes
This^^^
Z
Ziggyboy
Perfect, thanks fellas!! You guys are the best!!![emoji482][emoji482]
Z
Ziggyboy
Mans, you fellas know the part # for the front springs? Will the same z71 moog springs for the back work or is it a different part# ? Might as well change dems when changing out the rears.
Z
Ziggyboy
Would it all be the same coil for an LS to a Z71?
I have a Z71
scottd
