3-5 help
skyhighsami
I have a 2004 GMC Yukon XL with a DJM 3-5 and I need to do something to make it ride better. The rear is very stiff, the free travel mod has been done. Please let me know what can be done to make it better.
NORCAL SS
SUV SUSPENSION GURU
what color are your rear springs?
did you use the trailing arm kit/shock extender kit/swaybar endlink kit?
what shocks are you using? compressed and extended height?
skyhighsami
skyhighsami
I am not sure what color the springs are I will look when I get a chance. I did use the trailing arm kit and etc. I am not sure what shocks I am using as they are what came with the kit from DJM.
NORCAL SS
SUV SUSPENSION GURU
see what color the springs are
and i would change out the shocks to the belltech street performance ones.
Did you do the install?? just making sure that the swaybar endlinks and all that was intalled.
skyhighsami
skyhighsami
Yes I did the install....I am 100% sure we did everything on the back because it was a PITA as we did it off jack stands in the driveway when it was chilly. How good with the Belltech shocks ride compaired to what we have now? How likely is it that the issue is the coil?
NORCAL SS
SUV SUSPENSION GURU
THERE ARe 2 springs avil. thats why i need to know the color before we go on
skyhighsami
skyhighsami
Does blue sound right? It seems like I remember blue but to be 100% sure I will look
NORCAL SS
SUV SUSPENSION GURU
blue is the heavy duty springs thats why.
skyhighsami
skyhighsami
So, how much would a new coil be and should I replace it first then see or do both it and the shock?
skyhighsami
skyhighsami
They are light blue I thought I remembered them being blue. So what can I do?
Candielaine
