2dr 4x4 lowerd anyone????
Whippled2dr
Stock
SF Bay Area
so these till just bolt up? or im gunna have to do the same modification you did? and they will give me about 2 inches... the front dropped quite a bit...
They bolt right up using the stock bolts but you'll need to pull up the fuel filler hose or else the shackle will hit it.
Here is a pic of my truck with the keys and drop leafs.
Here is a pic with titan wheels. Again with the rear leafs. When I changed over to the shackle/hanger drop, the rear was 3/4" higher than with the leafs.
C
clean454
so that was just adding the shackles? to top one, thats what i want mine to looklike, i ordered the shackles hopefully i get them by the weekend, i will get pics up asap, when i get them thanks for all ur help whipple!
Whippled2dr
Stock
SF Bay Area
No. The above pics are with the drop leafs (which gave me a 4.5" drop). The shackles alone should only give you a 2" drop. If your front is too low you can crank up the keys and lift the front a little.
Also for reference the tires above are 28.25" in diameter.
This is what the drop leafs look like. You won't be able to tow with these unless you use some type of helper bags or something. Not my truck.
C
clean454
im prolly not going to do the extra 4.5 lower like u showed earlier, ill prolly just install the 2in shackle for now, i should be able to tow with just installing the shackle rite?
Whippled2dr
Stock
SF Bay Area
haha i kno im prolly a pain in the ass!!! but what if i got the flip kit?!?! and didnt mess with the shackles or hangers?!
http://www.stylintrucks.com/parts.a...|cat_-30|373=Lowering+Parts&partfamilyid=3326
Here is the flip kit for a 2wd 2dr tahoe (not 100% sure if the hangers are the same between the 2wds and 4wds).
http://www.stylintrucks.com/part.as...sults_trigger=&partfamilyid=3339&partid=12841
Instructions
http://www.stylintrucks.com/images/UploadedImages/instructions/FK10292D.pdf
I believe this kit uses some sort of lifting hanger to bring it up to 4" or the flip kit would drop it lower. Im not an expert on these thing so maybe someone else will chime in.
Here's belltech's flip kit. This one drops a 2wd 2dr 5.5".
http://www.stylintrucks.com/part.as...sults_trigger=&partfamilyid=3338&partid=19432
This one looks like it uses some type of lifting hanger too.
http://www.stylintrucks.com/images/UploadedImages/instructions/6640BLT.pdf
C
clean454
wow that looks like a bit of work, i think im gunna try the shackels and if that itsnt low enought i will prolly do what u did i like it better but im going to have to add some helper bags, thanks again for your help and i will let u kno what i do and add pic... thanks again for your help
PrinceTut
