2024 Denali Ultimate "Favorites"
chc4au
First World problem. I use about 6 satellite stations and flip through them using the switch on the steering column. One of the stations I listened to was replaced (same Channel Number) by a genre I do not like to listen to. Easy problem to solve! Go to settings then Audio hit button in upper right of screen and you can organize favorites. Have used this in the past no problem. Now go in delete station everything is fine until you turn off car and then turn back on and chanel reappears.
Have tried this 4 or 5 times even doing the reset (Hold down audio mute button until display resets) but channel comes back.
Any ideas other than learn to listen to PitBull channel?
Thanks for your help.
john1989
