2023 XL Denali ticking noise (this is the replacement truck for the one that had 2 engines die)
djsassan
Please tell me this is not the infamous ticking issue......
Just randomly started today. I remote started it and it didnt sound right, but I thought it was the car next to me. Other car drove off, open hood and voila. Tick tick tick tick tick.
D
djsassan
Good freaking grief.
11,500 miles on the car. One year anniversary of getting it as a replacement for the 21 Yukon that GM bought back after two engine replacements and a third issue in 8 months. *sigh*
Dealer has it, they need to tear it apart and see what's up. A tech jumped in it real quick, heard it and said "Oh that doesnt sound good." Not good when a tech says that.
I'm torn. I really want to initiate another discussion with GM, give this car back and go buy something else. This is 5 times in 18 months on two different Yukons. My contemplations:
1) I now have a 7yr/100k bumper-to-bumper GM warranty. That is REALLY hard to beat.
2) What other large SUV is out there. I need a Large one, not midsize. Suburban/Escalade/Yukon are all the same, so what is left: Navigator (a Ford? Oh goodness), a Landcruiser with zero bells and whistles made of plastic, or a Wagoneer. I have heard horror stories of Wagoneers, but to be fair I have had several Wagoneer rentals and all have been super nice.
Arggggghhhhh, here I am rocking a Corolla, and our Memorial Day roadtrip just got put on major hold if this what we think it is.
I am pissed.
Tahoe14
Central Fl
Good grief, I don’t think I would settle for anything less than a new one if that’s what you decide and an extended warranty for all your aggravation and wasted time , really hard to make you whole again after all this B.S.
WalleyeMikeIII
Sunny and Snowy Minnesota
You could lobby for a full size SUV rental for your memorial day trip...that seems to be the least they could do. Sounds like at least your dealer is going to bat for you? If so, use their goodwill. I am guessing they don't like the fact you are suffering any more than you do.
D
djsassan
My dealer has been awesome and worked with me on every single thing. I appreciate their efforts.
I'm waiting for an official diagnosis before deciding what I do next. I just want a vehicle that works.
tom3
Just amazes me that this superb engine design got corrupted with this absurd AFM system design.
Hrocks
I am pissed.
These horror stories on $100k GM trucks are nauseating. Was a LONG time GM guy. Get a Lexus LX or Toyota Sequoia, change the oil, rotate the tires and do the longer term maintenance stuff, and you you can drive them until you find something new and shiny 10 years from now.
Antonm
Wow, just wow.
I personally think it's the thin *** oil they're recommending (0W20) now, in conjunction with the cylinder confusion DFM/AFM system. The only reason they recommend 0W20 is for CAFE/ government mandated fuel economy reasons. The corvette (which is a slightly different 6.2 but it's more similar than it is different, especially in the rotating assembly) , recommends an 0W40, mobil 1 even makes a special dexos approved 0W40 just for it.
The previous LS engines (which again, are very similar in the rotating engine assembly part, they're just port injection vice DI) had no issues until AFM arrived and even after AFM the issues took a lot longer to surface, those engines ran a 5W30 for the most part.
tooleyondeck
Northwest FL
The L86/87 have the same compression, cam timing, and heads as the LT1, yet the LT1 hasn't been plagued with these lifter and rod bearing issues, even with the AFM components present. AFM/DFM are the downfall of the GM V8s. If I were spending upwards of 100K on a vehicle I would drop another few thousand to delete it and save myself the horror all these guys are going through.
Antonm
But then you’re stuck with a brand new $100k vehicle that has no warranty. So there is a downside.
DontTaseMeBro
Wow, just wow.
What’s stopping us from putting in a different viscosity/weight oil other than those of us with warranty still? Like would be the downside(besides fuel efficiency)?
Antonm
Nothing is stopping us, in fact I am using 0W40 oil in my 6.2, and the one used oil analysis I've done so far looks pretty good.
As for warranty, well, it's a lot easier to drain and replace the oil should the engine happen to blow up than it would be to put the DFM system back on.
Back in the early 2010's I used to have to put the DPF system back on my common rail diesel truck every time I needed to take the truck in even for non engine issues (like one time I had to put the DPF system back on when the dang factory navigation / radio/ infotainment head unit quit working to keep them from voiding the warranty on the truck)
15burban
Wisconsin
How long did you run the 0w40 for? Which oil did you use? Did it stay a true 40 wt the whole interval? From reading others oil analysis about pennzoil ultra platinum 0w40 it usually shears down to a 30 weight around 1k miles or so.
Antonm
I used mobil 1 , 0W40 euro oil, which even new is barley in the 40 weight range. I posted the oil analysis results in another thread (link to that other thread below). I only ran the oil in the analysis for 3K miles (the time between 3K and 6k miles on the odometer), but it stayed a 40 weight (barley) for that long.
Antonm
One is GM dexos approved (the super car stuff) and one isn’t ( the euro stuff).
I’d imagine they have different formulations in the additive package, like maybe less zinc/ phosphorus and more moly in the dexos approved stuff, but that’s just a guess.
DontTaseMeBro
I’m going to change the oil soon and will put in 0w40. I still have one empty container available for Blackstone sampling, so I’ll be sending it off. My engine has 13k on it.
wwiizz
