2021 Tahoe not working right
Danparker34
My wife was driving my 2021 Tahoe on the highway and the car switched to neutral on it own and started shaking. The car would not go back to drive, all the gauges were going crazy, and the radio would not turn off. Now the car will not turn over and the starter keeps going even when the ignition is not pushed in
Micahsd
That’s not great. May have to pull the battery cable for a bit to get that to stop.
If the starter is not turning the engine over after going through that kind of issue prior, kinda wonder if there’s something major going on with the engine. If it was a lifter that went bad (which I had happen to my ‘21) it should still turn over unless it bent a bunch of rods or something causing it to lock it up.
Hopefully you have powertrain wattery coverage still?
veteran111
