2021 RST rear panel removal?
West1
My RST has bad rattling due to my sub. I can’t figure out where the bottom bolt that holds both side panels. Anyone know how to remove the inside panels between the 3rd row & trunk?
Tyvm
WalleyeMikeIII
Sunny and Snowy Minnesota
See if you can find the instruction sheet for the illuminated rear sill plate, I think the side panel has to be removed for that. Check the GM accessories store.
W
West1
Can’t find anything, anyone remove the rear panel?
W
West1
I would think once you get the D pillar and stuff off, there are either bolts or clips holding that interior panel on?
Correct. There are bolts near the hatch and near the seatbelt. There are some clips near the rear window but I still can’t get the panel off. Both sides have something stuck either in the middle or the bottom.
scottd
