2021 or 22 Big3 upgrade anyone?
West1
Has anyone upgraded the factory ground?
I’m pushing about 2k rms and surprisingly no dimming lights or signs of power struggle. With that much power, I need to upgrade ground to match my amp 1/0 wiring.
Fast_AT4
RWM +1
SW Florida
BIG3 cant hurt.
Interested in your wiring (power/source/remote) setup for amp/LCi...and such. Pics if you dont mind :)
W
West1
Anyone know if there’s a sensor the big3 has to bypass? If so, who and where did you get the bypass from?
Jackal9580
From what I've seen on mine, no. I have the 3l 6 though. Just appears you need to run it from the alternator to the busbar on the battery. Easiest way would be to run 1/0 in addition to the factory stuff. Allows the amperage you need while retaining the factory wiring as well.
Side note, where'd you ground your amp?
Stresst
2k is nothing! Ground your amp/amps to the chassis.
What amps are you running? What subs?
worleytrev93
