2020 Tahoe Intermittent Wiper Speeds Erratic
BEagen
LI, New York
2020 Tahoe - When I select the intermittent low speed setting on my wiper switch, it starts out at the lowest speed then after about 30 seconds, it speeds up. Usually speeds up to a medium speed but once it went all the way to the high speed. If I turn it off and reset, it does the same thing. No way to set the intermittent speed using the switch. The low and high continuous settings are unaffected and work fine. If I want an intermittent function, I have to manipulate the switch manually.
Miami-Dade
Super Moderator
2020 Tahoe - When I select the intermittent low speed setting on my wiper switch, it starts out at the lowest speed then after about 30 seconds, it speeds up. Usually speeds up to a medium speed but once it went all the way to the high speed. If I turn it off and reset, it does the same thing. No way to set the intermittent speed using the switch. The low and high continuous settings are unaffected and work fine. Don't have the rain sensing option. If I want an intermittent function, I have to manipulate the switch manually.
Welcome from Miami&NYC
Moved you here from 2021+section
Off Road Pedia
