2018 Yukon slt towing
Dayrider715
What size campers are you guys pulling with a 2018 Yukon slt 5.3L. I am looking at a 29 ft that weighs 5100 dry with a gvwr of 7300. Not sure how much the tongue weight is, will find out this weekend when I double check everything. Trying to see if I will have issues towing it
NIevo
Lewiston, ID
Do you have the tow package? If so then that trailer should be no issue but would definitely still use a LD/Sway hitch.
tungsten
I pull 6000 empty with a 6.0 2500 truck.Dont think Id want anything less.Hills ,head wind can make it pretty ******* a unit.
edit h ard on i guess is a bad word lol
Geotrash
Dave
Richmond, VA
XL or shorty? You’ll have quite a bit more sway with the shorty, but a good WDH will help. Ours is 7000-7500 fully loaded and I pull it with a Yukon XL Denali but lots of folks are pulling campers that size with the 5.3. As others have said just verify that you have the external transmission cooler option.
Geotrash
Dave
Richmond, VA
A 2500 would be ideal, of course, but with a good hitch the 1500’s are capable towing beasts. I’ve made several modifications to mine (towing cam, 2-row radiator, fan forced transmission cooler relocated below the radiator, billet torque converter, 700w fan motor, etc) to better handle high temps in the south and mountain west. I have pulled over 20k miles with this setup and it’s solid, comfortable and stays cool.
tungsten
Well I guess with all the mods then that for sure helps. I just go by what I see on the roads. A small truck like a Tahoe just doesn’t seem right pulling a 29’ trailer.
trevsyukon
