2016 PPV Tahoe To Modified Civilian
Jibber
Just purchased my first PPV that I will drive. Wanted to document the before pics and also discuss any issues that arise along the process.
First- after review of some threads, I checked my windows and doors. All work inside and out, front and rear. My left rear interior door handle is on the verge of popping out and can’t be saved. Have to buy entire panel and that’s $138 at junkyard. Also the rear seat is in good condition and I plan to switch the fronts to leather. It’s cheaper to buy two front leather seats than one rear 60/40 bench cloth.
Also read up on the console issues so, I will be diving into that. Console is 350 at junkyard. Picking all this up today.
Exterior plastic pieces that go around black glass have holes, those pieces are 80 any way you go. Apiece! Also interior pillar on drivers side where the spotlight was I am replacing - $30 new.
I can spend a little on it because I feel like I stole it. $8500. With 174k miles.
Welcome to the Forum from NH.
Nice find.
Sparksalot
Bastrop County, Texas
View attachment 383184Just purchased my first PPV that I will drive. Wanted to document the before pics and also discuss any issues that arise along the process.
Where in Texas?
J
Jibber
First problem of the day- I am unsure if I can swap this type of front seat - split bench I guess is what it’s technically called to a leather bucket. Different codes mine is AZ3 and my husband is at junkyard and not quite sure it my wire harness will work with another style. Don’t want to dive off that deep into mods at this point. This is my wiring connection.
Thoughts? If it’s not too difficult a change this I would do it but
Sparksalot
Looking closer, that seems like it would physically connect.
Chickensandwich
Save some money for future lifter issues. Being a 2016, adding car play might be fun. Perhaps a nice leather steering wheel instead of the cheap plastic one? Being a PPV, I would replace the cabin air filter. I got my PPV from dusty dirty Texas (no offense) and it was clogged with dirt and leaves. Check under the seats…I found a nice Whelen speaker, a Vascar III unit, and a gas credit card (returned to the sheriffs dept). Do you have a center console yet? Have fun with the truck. You can put some money in to it and have a lot fun.
J
Jibber
Found a jump seat console - never been sat in and replaced the rear seat versus the front two. It had also never been sat in. Had to cut out pieces in the flooring to make the center console bolt in. I kept the steering wheel. It's not the cheap plastic. Doesnt have all the buttons for controls, but oh well. I kept the small factory radio. Put a new set of tires on it and got a some factory chevy rims from a regular tahoe. Gave my son the black steel wheels that were on it. Worked out good, they had really good tires on them so he doesn't have to buy new tires.
Chickensandwich
I believe you can simply replace the small screen with the larger 8”. A nicer big screen for around $250 on ebay
Hodmjstone
