2015 XL Denali leaking antifreeze
Tahoe14
Central Fl
You may want to do a Google search as I believe there was a bulletin for weeping from the side tanks of the radiator on the 2015 Chevy, GMC and Cadillac SUVs unless your is an obvious leak.
Pittz
What's the goal of this thread?
So, when someone else has a leak like him, they can google the problem and possibly find their solution. He was hopeful someone else could have had the same problem and chime in. One can hope the OP replies with a solution. That's the goal, Chief!
CMoore711
When someone else has a leak like him....? Do you realize how many different places antifreeze could be leaking from? There's no details to his problem to even begin to get close to a potential solution or to even offer any real help or guidance.
michiganlebnani
Michigan, Metro Detroit
Relax guys I am sorry if I offended anyone with this thread. Anyhow here is the finding at the dealership: technician performed a pressure test and ruled out that a bad clamp causing the coolant to leak from the lower hose going into the radiator.
He replaced the clamp and re-tested and it was ok. I have been driving it for two days now and no leaks !!!
Miami-Dade
Moderator Supporting Member
Glad it was only a minor issue and was fixed quickly.
You did not offend anyone. I think some people were having a bad day.
Pittz
He started a thread AND finished it. This is exactly what a forum is for. He did not ask a question, only STATED his problem. You are of zero help on this thread.
Pittz
Glad you got it figured out and responded with the problem. Nothing worse than someone trying to crap on someone else thread, especially when they have a problem with their vehicle.
CMoore711
You're right Pittz, I should have contributed to the thread in a more positive manner, I'll take that. I'm glad you were able to respond to the OP's stated problem and help him get to his solution, thanks for your help.
Glad it was an easy fix OP.
mfinta
