2015 Tahoe LT 20x10 -18 wheels
Sky329
Hi all,
quick question. Stock tahoe suspension, no lift. Will 20x10 -18 wheels fit with a 275/55/20 tire with no lift or rubbing? Thank you.. Really couldn't find this answer online
Big Mama
Virginia
Welcome to the forum from Virginia. Depending on the wheel offset it should work but that’s a wide wheel on a not so wide tire. If you’re getting the new shoes as a combo any reputable dealer will put one on to make sure it fits. Again, offset is the key.
CMoore711
Why such a narrow tire on a 10" wide rim? That fitment will have a stretched tire sidewall look for sure; Which is ok if that's what you're going for.
The rim width and offset will likely rub on a stock suspension stock ride height Tahoe.
This website isn't the gospel exact fitment guide for every car model; But it gives you a pretty good idea when you compare the new rim and tire specs to your existing rim and tire specs.
Drewphil
