2015 Tahoe..HID bulb burned out. Need good replacement
elperuano
Cape Coral SWFL
Ordered a set of Vanquish HID lights more than a year ago and my left bulb burned out. What's a good compatible bulb I can use to just swap out the bulb? So many options on Amazon I'm not sure which one would fit my 2015 chevy Tahoe.
TIA
E
elperuano
Cape Coral SWFL
I don't have stock hid. I bought a set of vanquish hid kit for my Tahoe. I think the one you recommended is for stock hid.
CMoore711
Did your Tahoe come with Haolgen headlight bulbs in the low beams from factory? If so your low beam bulb is probably an H11 bulb.
I'm not sure if Phillips, OSRAM, offer OEM type H11 HID bulbs.
Then you installed an HID kit from Vanquish with ballasts etc.? I'd check TheRetrofitSource to pick up some replacement H11 HID bulbs.
https://www.theretrofitsource.com/hid-parts/hid-bulbs-h-series
E
elperuano
Cape Coral SWFL
Spot on with your advice. Ordered a set of h11 hid bulbs and swapped out but still didn't turn on. My high beams work but no low beams. I guess my ballast took a dump but I thought then the high beams wouldn't work neither. Gonna need to buy a set of HID ballasts now
Offroad Tahoe
