2012 Yukon XL Denali seat issues
BSarteSr
I just bought a 2012 Yukon XL Denali and have a few questions that I hope someone can help me with.
1st one, the front passenger seat. No power to it at all when I try use any of the switches on the side. Looked underneath and all the plugs seem to be in place. Also looked at the fuses and did see any on the diagram that would indicate a fuse for the seat?
2nd question. Passenger 2nd row arm rest. Will not stay up. Took the bold off and all looks good, when I put it back made sure bolt was tight but still does not stay when in the down position.
Comments please.
mikez71
Regarding seat fuse, there seems to be fuses on left side of instrument panel, and a circuit break under dash by pedals..
Driver seat module? Fuse 25?
It looks like the receiver for your tire pressure monitors uses the same fuse.
(and possibly remote entry but I haven't looked at that wiring diagram yet).
So if you are seeing your tire pressures, it's probably not that fuse but the breaker, a bad module, or something else..
BSarteSr
BSarteSr
I just looked at the tire pressure and it shows but seems a bit weird, the front shows 35 for left and 34 for right, the back shows exactly the same. I need to add some air to see if it changes and if it does not then might be the fuse, if the air pressure does change then most likely not the fuse/relay but it can't hurt in changing the fuse or relay.
mikez71
Yea, that sounds like the fuse is probably working.. I guess you could remove that fuse and see if your tire pressures still read..
Here's a few diagrams that might help..
6205 circuit, purple/white wire looks like that is power for the switches...
BSarteSr
BSarteSr
I just put air in the tires and the pressures changed, so that rules that fuse/relay out.
mikez71
I would check for juice at the memory seat module, J3-5.
That's the wire from the circuit breaker to the memory seat module.
Also check J3-3, which should have power from the memory seat module.
BSarteSr
BSarteSr
J3-5 says it is "circuit breaker"? Relay or fuse?
I just bought a 2012 Yukon XL Denali and have a few questions that I hope someone can me with.
Comments please.
put a small sleeve on the arm rest bolt then tighten it up again, they only sink in so far so a sleeve allows you to get it more snug.
I also recommend using some blue lock-tight on the bolt threads otherwise they tend to work there way loose again
if the caps are missing there are plenty on ebay amazon
Comments please.
Download a code reader app to your phone that can read ABS and BCM codes. The codes will tell you what is wrong and why or at least where to start looking. Of course, this gets paired with an OBDII adapter, Bluetooth or WIFI to talk to the phone.
Drybone81
