Hi everybody, thanks in advance for the assistance.
I'd rip my hair out if any was still left trying to figure this out.
My trailer lights were intermittent at best and finally stopped working. Narrowed it down the the yukon side of things. No power coming out of the 7 pin connector.
I removed the trailer side of the 7 pin connector and tested the yukon side, no power.
I checked fuses and all were good.
I cleaned off the ground connection and tightened it back down.
Then I tried connecting the test light to the fresh ground and still nothing.
Can the ground wire that connects to the 7 pin be loose or bad?
Is the ground location, in the rear body mount, not a good location?
Should I clip the wiring and 7 pin pin and install new wiring?
Thanks for the assistance!
