2010 Yukon electrical problem - heat and cruise
JohnCaper
I replaced the radio with a touchscreen "infotainment" radio. I decided not to use the steering wheel controls because I've read that needs another module. Got it all up and working but now the cruise won't engage (I can turn it on and off) and the heater won't blow heat. I'm going through checking fuses. The cig lighter fuse was blown. Would that also control the other systems?
Any other thoughts?
JohnCaper
JohnCaper
Update - passenger side vent blow hot, driver's side blows warm. I pulled the HVAC Batt fuse for 10 seconds. I'm going to try that again and leave it out longer to see if it recalibrates.
Brake light switch works for the brake lights - cruise still doesn't work
There are other feeds from the cigarette lighter circuit.
You should really get the integration module that allows operation of the steering wheel controls.
JohnCaper
JohnCaper
Heat is working now as well. Cruise is the only thing not working. Is it possible that the switch works for the light but not the cruise?
I believe that you may need that integration module to regain your cruise control.
petethepug
Michael
SoCal
Not sure. Can you supply data on name & model of what radio was installed and potentially info of how mfgr addresses lack of steering wheel controls.
Malakas
