Saint James
Hi, I have 2010 Denali, power tilt does not work. Pushing switch on column up or down does nothing. Everything else works, except for the AC cooling in passenger front seat (which I understand to be a second issue to address separately). Memory works, both heated seats, power seats, etc., so I dont thinknits the module. Can I bypass the switch to move the wheel? I just want to move it down about an inch or so and never move it again. Can I open up the column cover and possibly move some gear with a flathead screwdriver or use some other mechanical override?
There is very little info or discussion on the web about this. I did learn that the motor is hard to find and costs around $100, if you can locate one. But I haven't seen any youtube vids on how to replace the motor if needed, how to troubleshooot or repair, etc...
Any information from your fine establishment would be appreciated.
Thanks in advance.
Thanks in advance.
