strokersace
- Joined
- Aug 8, 2022
- Posts
- 18
- Reaction score
- 41
New member trying to search and learn as much as I can in short time. So my apologies if I missed this swap already being covered. Most I see are a 5.3 to 6.2 swap. We bought our 2008 LTZ Suburban 1500 4x4 several months back and so far it's been great (minus the fuel economy). Factory optioned L76 6.0 with AFM & VVT, 4L70e trans, GT5 rear axle 4.10 gears, and G80 locking diff. It's mainly the family vehicle, grocery getter, and occasionally tow a little.
Last weekend on our way home from vacation, #6 misfire and stabilitrak went off. Noticeable lifter tick, rough idle, down on power, etc. Was planning on just rebuilding with AFM delete, cam, tune etc. HOWEVER, I just came across a good running L9H 6.2 from a wrecked 09 Denali about 45 minutes from my house for not much more $$ than the parts to fix the 6.0. Drop it in, tune with Blackbear, and go.
Thoughts? Anything I should do to the 6.2 before putting it in? Was thinking of just leaving the stock vvt cam in since it's already a non-AFM engine, but could be convinced otherwise. Was researching doing a 6L80 swap, but will be keeping the 4L70 for now. Same with axles, unless I can find a donor 14-bolt 3.42 along with front. The 6.2 does not have a flexplate on it. Can I use the one from the 6.0 along with the stock torque converter?
Been wrenching for a long time, mainly on the diesel side so not afraid of a custom setup. Just not much experience on the LS side of things. Any insight is much appreciated!!!
