2007 Denali power steering question
thebaum
I have an 07 Denali and I'm tracking down a squealing in the engine. I'm pretty sure it's the power steering. I'm having zero power steering issues other than the squeal.
My question is this, I have the pulley off and a new one in hand, but should I go ahead and replace the pump and lines? Or should I just try to replace the pulley and see if that works?
Thanks for the input
Onlyone
New Mexico
Have you looked at or replaced the tensioner? Quite a bit of the time the tensioner gets weak and doesn’t tighten the belt as needed and it slips and squeaks.
T
thebaum
Yeah I replace the tensioner and the older pulley as those were simple and cheap
TollKeeper
Brighton, CO
Have you replaced the belt to be sure the belt isnt stretched out? Power steering pulleys never go bad unless a large outside force has acted upon it (like a wreck).
T
thebaum
Belt is pretty new but I did get a new one to put on but I already had it apart for the power steering. Maybe I should put it back together first before I proceed and see if that fixes it!
Geotrash
Dave
Richmond, VA
That's what I would do. Also, even a slight misalignment between the pulleys on these can cause squealing.
Yes, put it back together first and see if the squealing stops. I'm assuming that you have not experienced any loss of power steering fluid.
petethepug
Michael
SoCal
Glad you’re addressing this right away. Losing that accessory belt at any speed turns the truck into an unstoppable, unsteerable 3T freight train. Ask me how I know. I had 6 kids in the 08 YXL Denali at the time going 60 getting off the freeway.
I got the Gates HD green colored belt kit off Amazon that comes with a new A/C stretch belt. All with a lifetime guarantee.
brice715
