2006 Yukon XL SLT option 2
Woodblocker55
I have heated front seats. But is it pretty hard to add heated seats for the rear seats ? I seen Denali has buttons by the rear center control . Is there a alternative? Or do I need to go on a junkyard hunt ..
Heated seats are dam nice in Minnesota lol.
Sent from my LGL84VL using Tapatalk
rgosart
Do you have captains chairs or a rear bench? I added some aftermarket heaters in my car that I use to commute and they were very simple. Might be a good alternative to trying to find and make a factory system work. Just need a switched power source and a place to mount two small switches.
Something like this
https://www.amazon.com/WATERCARBON-...23&hvtargid=aud-799728744414:pla-568066674406
Now they're far from premium but for some rear seat heat, they work fine...
Woodblocker55
Woodblocker55
Something like this
Yes I have rear captain seats . When I install them I could put switch's on council like stock great alternative. Do I need to worry about foam in stock seats ? And when wired right do they auto shut off like stock ones ? That's awesome they make them .
rgosart
No. The foam for heated seats isnt any different than the foam without heat. They'll shut off when the key is off, but they dont automatically shut off and stay off with the next key cycle like the factory heater .
Woodblocker55
Woodblocker55
Thanks for the info . Might need a timer ciruit in it . There has to be trick to fix that . That's great info thanks... when I install them I post how it worked out .
Durobans
