2006 Tahoe Recommended Maintenance?
edgil1985
Alabama
I searched and couldn't find any info. Where can I find a list of the recommended maintenance? My Tahoe has just under 140K.
E
edgil1985
Alabama
I have owned since around 80k-90k. I have had the transmission serviced, I replaced the heads with new ones I had lying around due to an exhaust valve leak, New water pump after about 100k due to a leak, new power steering pump twice but last time was actually the alternator being the culprit but didn't figure it out until the pump was already changed, new plugs and wires shortly after I got the Tahoe. I'm sure I'm forgetting somethings.
4motion
If you do not when the following service has been done, I would also do a brake fluid change, diff's service and air filter.
E
edgil1985
Alabama
I haven't done the brake fluid change or Diff Fluid change. I have the Airaid Tube and KandN Filter that's I put on it not too long after I bought it.
JPeter
