2004 Yukon power seat will not move forward
ta6point6litre
So I just bought a 2004 GMC Yukon Denali and one of the many little things I need to fix is the front drivers side power seat. All the other power seat functions seem to work except I cannot move the seat forward. I originally thought it might be the switch. If I disconnect the harness for the motor and apply voltage with my power probe the seat does move forward and backwards, so I know the motor works. I tried another switch but it did not make a difference. Any ideas?
Welcome to the Forum from NH.
Lots of folks here with deep experience on these trucks, and they will chime in with suggestions and perspectives.
When you directly connected power to the motor, bypassing the wiring harness, did you apply both a 12v connection and a ground connection to the motor? I'm asking, because disconnected or poorly connected ground wires can create issues, and you want to make sure that you have both a good 12v power connection and a good ground connection to the motor. Perhaps, the ground connection through the harness has an issue with it. (or perhaps, the motor is directly connected to ground through its housing, but I doubt it.)
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
When you directly connected power to the motor, bypassing the wiring harness, did you apply both a 12v connection and a ground connection to the motor? I'm asking, because disconnected or poorly connected ground wires can create issues, and you want to make sure that you have both a good 12v power connection and a good ground connection to the motor. Perhaps, the ground connection through the harness has an issue with it. (or perhaps, the motor is directly connected to ground through it housing, but I doubt it.)
Good call, Joseph.
ta6point6litre
ta6point6litre
Actually, at first the power seat on the driver side did not work at all. I did some online research and found a bunch of people saying the main harness under the seat can cause this problem. I unplugged it and did see some corrosion on the ground pin. After I plugged it back in everything worked except the seat forward control.
ta6point6litre
ta6point6litre
Figured it out. Before I unplugged the main harness under the seat I had removed the power seat module from the plastic case. I did not realize the 2 plugs that connect from underneath were not completely pushed all the way back in because they are pretty hard to see. Now everything is working properly.
OR VietVet
Willamette Valley
Basics win again. I would lose track of how many times we here have told posters to recheck any recent work done in the area of the current problem.
Thank you for reporting back with the results of your issue resolution. Very much appreciated.
We have added to the knowledge base (watch out for these two hard-to-see connectors when working on seat electrical systems), and re-affirmed best troubleshooting practices (re-look at any recently performed work, to see if it is somehow related the current issue).
ta6point6litre
ta6point6litre
Like I said, when I first started I had no functionality on the driver side power seat. One of the first things I read online said that the seat was controlled by the power seat module under the drivers side seat, so I checked that first by removing and re-installing the board. What I didn't realize was that the connections on the bottom of the housing were actually connectors that could be unplugged from underneath. I thought they were part of the housing itself. When this didn't change anything I moved on to checking the main harness not knowing that the connections were loose on the power seat module. After cleaning the ground pin on the main harness, everything worked but the forward control. Only found out about the plugs on the power seat module by accident. I had my hand under the seat while trying the controls and it moved for a second. Realized I was putting slight downward pressure on the housing for the power seat module. Long story short, if I had started with the main harness I would have never touched the module and never had an issue. Hope this helps someone else.
Drewphil
