Fatmikeslim
- Joined
- Jun 18, 2017
- Posts
- 3
- Reaction score
- 0
help me please im freaking lost.......
Bought an 04 Tahoe to make a road trip vehicle (third row big crew).......
And the ac didn't blow frosty air ' just cool....... The person i got it from told me it has a new ac control head (still has plastic stickers on it) and was unsure what to do next........ so i bought it cheap with the intentions of fixing the problem and having a nice people hauler...... first thing i did was check the pressures it was 95f outside and the low side pressure was 90psi and the high side was 300psi.........whoa i know.....
So after a couple mins of thinking i washed the condensor out (that wasn't bad) the head pressure dropped some. But soon returned to close to 300psi. So i figured it was way over charged' i pulled a good vacuum on the system ' let it sit 2hours and recharged it with 44 oz of 134a (it has rear air)....... exact same pressures......... then thought ok high head high low air flow prob so i swapped out the fan clutch..... now we're like 280 psi head but still 64f degree air in center vent. After talking to a friend he convinced me to swap the compressor ' orifice 'and drier' and expansion valve ' what a chore...... vacuumed again 30mmhg' held for 2 hours ' and recharged 44oz of 134a.......now the low side is 65psi and the high side is 275 dash air 62f.....rear air 62f. ........ if i vent some 134a the dash air instsntly gets warmer and if i am scared to add more because of the high pressures.......... i also washed out both evaps really good and have good airflow ............ i don't think its blend doors the operate awesome ' and the pressures show the same temps as the freon does...... The cold side of the evap up front is sweating bullets and COLD ' the out let of the evap is cool ish ...............i feel like its first and goal ' and im punting .........i honestly am lost now and want cold air
