2002 Tahoe brakes
02_Tahoe
Maryland
I have recently bought a 2002 Tahoe, but it was sitting for over a year and the brake pedal goes all the way to the floor, the brakes still work but it's you have to hit the brakes harder than you should, does anyone know what it could be?
mooman
Saint Paul
I would look to see if there are any leaks. Check by each wheel to make sure you aren't spilling brake fluid everywhere. next, Check around the floor of the driverside. Leak be the wheel is a busted line. leak where the drivers side floor is Brake master cylinder.
Eric70
If you don't see any leaks, and your master cylinder reservoir is full, it's most likely the master cylinder itself leaking internally.
Eric05z71
I have changed all rotors, pads, caliper brackets and pins and it still seems hard to brake, my reservoir is full. Could it be a brake booster or the master cylinder? If so how hard of a replacement is that?
Eric70
If your brake pedal slowly but eventually travels to the floor!, I would say it's the master cylinder. If it doesn't go to the floor, might be the booster. Check the vacuum hose for any cracks or loose connection.
massivespl
I'm not mean, I'm honest.
Michigan
Tahoe are just big to stop. Lol my brake is like yours too. All new brakes and everything is working proper but the pedal has to be like half way down to start stopping... Even my dads 2001 Silverado feels the same way... Then I drive my wife's Grand Prix and brake check myself and about hit my face on the steering wheel the first time using her brakes.. Vehicles are different.
02_Tahoe
02_Tahoe
Maryland
Lol. But my pedal went down about 3/4 of the way before slowing down but I found out that 2 of the calipers weren't even working
bottomline2000
Dallas, TX
Hydroboost would help that stopping problem.
Sent from my SAMSUNG-SM-G900A using Tapatalk
JamesinAbilene
