Ialsofkdyourdad
- Joined
- Feb 27, 2021
- Posts
- 26
- Reaction score
- 7
Hey I posted before but I was able to scan it and it was a bit weird
At first it only had c0308 which is a voltage issue, I saw online people had fixed it by cleaning ground points and the connector. so I went under the truck and cleaned the connector and unbolted the ground points, hit then with a flap wheel and grinder reattached them and painted the showing bare metal
I went up and the truck still had the service 4wd system and no lights I rescanned the truck and it now has c0308 and c0327. Before I order the encoder motor is that for sure what these codes mean or is there anything else I should check?
Also is there any way to know if the encoder is splined or keyed without taking it off? If not I'll order both and return the one I don't use
