2000+ rear air suspension
yates ™
yates ™
Resident Apple hater
Iowa
all 2000 up to 2013 its the same upper and lower mount gm never changed anything
I was 90% sure that they are exactly the same but want to be 100% before sending this out to others.
Administrator
Would pics help Yates? Or do you need exact measurements or what? Tell me what you need and I'll try and get those for you tonight.
yates ™
yates ™
Iowa
Exact measurements would be best. I am going to have a mount for the compressor cut out so that everything is completely bolt on.
Can you also get me a measurement from the frame to the bumper so I know how wide the base can be.
If someone was close enough and would let us use the truck for a couple of days I would make you a really good deal on this kit.
Administrator
The one thing I need to figure out before actually making this available is mounting of the compressor. Can someone do me a favor and see if the three factory mounting holes on the frame for the factory compressor on the non factory air suspension models? Also is present on NBS and NNBS?
Mine not being an AutoRide model can you tell me exactly where to look so that I get the proper information for you?
yates ™
yates ™
Iowa
I am hoping/guessing there will be the three holes behind the drivers side wheel.
Administrator
:waytogo: I'll take a look tonight and get you what you need unless someone else gets it for you sooner.
drhdvm
